teste mal... ;-)
[HTML]<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="content-type" content="text/html; charset=ISO-8859-1">
<title>Menue</title>
<style type="text/css">
.menutitle {
cursor:pointer;
margin-bottom: 5px;
color:#000000;
width:140px;
padding:2px;
text-align:center;
font-weight:bold;
border:1px solid #000000;
.submenu{
margin-bottom: 0.5em;
</style>
<script type="text/javascript">
* Switch Menu script- by Martial B of
http://getElementById.com/
* Modified by Dynamic Drive for format & NS4/IE4 compatibility
* Visit
http://www.dynamicdrive.com/ for full source code
var persistmenu="yes" //"yes" or "no". Make sure each SPAN content contains an incrementing ID starting at 1 (id="sub1", id="sub2", etc)
var persisttype="sitewide" //enter "sitewide" for menu to persist across site, "local" for this page only
if (document.getElementById){ //DynamicDrive.com change
document.write('<style type="text/css">\n')
document.write('.submenu{display: none;}\n')
document.write('</style>\n')
function SwitchMenu(obj){
if(document.getElementById){
var el = document.getElementById("sub"+obj);
var ar = document.getElementById("masterdiv").getElementsByTagName("span"); //DynamicDrive.com change
var art = document.getElementById("masterdiv").getElementsByTagName("div"); //DynamicDrive.com change
if(el.style.display != "block") { //DynamicDrive.com change
for (var i=0; i<ar.length; i++){
if (ar[i].className=="submenu") //DynamicDrive.com change
ar[i].style.display = "none";
art[i].style.backgroundColor = "#ECECFF";
el.style.display = "block";
document.getElementById("topmenue"+obj).style.backgroundColor = "#ffcc00";
} else {
el.style.display = "none";
document.getElementById("topmenue"+obj).style.backgroundColor = "#ECECFF";
} // document.getElementById
} // ende funct
function get_cookie(Name) {
var search = Name + "="
var returnvalue = "";
if (document.cookie.length > 0) {
offset = document.cookie.indexOf(search)
if (offset != -1) {
offset += search.length
end = document.cookie.indexOf(";", offset);
if (end == -1) end = document.cookie.length;
returnvalue=unescape(document.cookie.substring(offset, end))
return returnvalue;
function onloadfunction(){
if (persistmenu=="yes"){
var cookiename=(persisttype=="sitewide")? "switchmenu" : window.location.pathname
var cookievalue=get_cookie(cookiename)
if (cookievalue!="") {
document.getElementById("sub"+cookievalue).style.display="block";
document.getElementById("topmenue"+cookievalue).style.backgroundColor = "#ffcc00";
function savemenustate(){
var inc=1, blockid=""
while (document.getElementById("sub"+inc)){
if (document.getElementById("sub"+inc).style.display=="block"){
document.getElementById("topmenue"+inc).style.backgroundColor = "#ffcc00";
blockid = inc;
break;
inc++
var cookievalue=(persisttype=="sitewide")? blockid+";path=/" : blockid
document.cookie=cookiename+"="+cookievalue
if (window.addEventListener)
window.addEventListener("load", onloadfunction, false)
else if (window.attachEvent)
window.attachEvent("onload", onloadfunction)
else if (document.getElementById)
window.onload=onloadfunction
if (persistmenu=="yes" && document.getElementById)
window.onunload=savemenustate
</script>
</head>
<body>
<!-- Keep all menus within masterdiv -->
<div id="masterdiv">
<div class="menutitle" style="background-color: #ECECFF" id="topmenue1" onclick="SwitchMenu(1)">Site Menu</div>
<span class="submenu" id="sub1">
- <a href="cm1.html">Menuelink 1</a><br>
- <a href="cm2.html">Menuelink 2</a><br>
- <a href="revised.htm">Revised Scripts</a><br>
- <a href="morezone/">More Zone</a>
</span>
<div class="menutitle" style="background-color: #ECECFF" id="topmenue2" onclick="SwitchMenu(2)">FAQ/Help</div>
<span class="submenu" id="sub2">
- <a href="notice.htm">Usage Terms</a><br>
- <a href="faqs.htm">DHTML FAQs</a><br>
- <a href="help.htm">Scripts FAQs</a>
</span>
<div class="menutitle" style="background-color: #ECECFF" id="topmenue3" onclick="SwitchMenu(3)">Help Forum</div>
<span class="submenu" id="sub3">
- <a href="http://www.codingforums.com">Coding Forums</a><br>
</span>
<div class="menutitle" style="background-color: #ECECFF" id="topmenue4" onclick="SwitchMenu(4)">Cool Links</div>
<span class="submenu" id="sub4">
- <a href="http://www.javascriptkit.com">JavaScript Kit</a><br>
- <a href="http://www.freewarejava.com">Freewarejava</a><br>
- <a href="http://www.cooltext.com">Cool Text</a><br>
- <a href="http://www.google.com">Google.com</a>
</span>
</div>
</body>
</html>[/HTML]
